size-neutral parameters
Сообщение rilli » Вт сен 04, 2018 11:22
Здравствуйте!
Помогите, пожалуйста, перевести:
size-neutral parameters и connection-point-neutral approach
в контексте: given this size-neutral and connection-point-neutral approach, power converters will need to calculate an effective percent value for the locally measured voltage
Спасибо заранее
rilli
Re: size-neutral parameters
Сообщение Pipelineman » Вт сен 04, 2018 13:48
соответственно:
"параметры, не зависящие от размеров"
"подход, при котором не принимается во внимание расположение [либо тип или иные параметры - надо глубже в контекст врубаться] точки подключения"
Pipelineman
Язык(-и): En <=> Ru
Сообщение borysich » Вт сен 04, 2018 14:53
"... 2.2.4 Percentages as size-neutral parameters: voltage and var calculations
As noted previously, because broadcast/multicast commands cannot necessarily know the size or capabilities of an inverter, the curve settings are generally in percentages of nominal or
nameplate values, rather than absolute values. That approach permits both small and large inverter-based DER systems to respond within their limits.
In particular, given this size-neutral and connection-point-neutral approach, inverters will need to calculate an effective percent value for the locally measured voltage as follows ..."
http://xanthus-consulting.com/Publicati ... 0-90-7.pdf
"... 1.2.4 Percentages as size-neutral parameters: voltage and var calculations
As noted previously, because broadcast/multicast commands cannot necessarily know the size or capabilities of an DER system, the curve settings are generally in percentages of nominal or nameplate values, rather than absolute values. That approach permits both small and large DER system-based DER systems to respond within their limits.
In particular, given this size-neutral and connection-point-neutral approach, DER systems will need to calculate an effective percent value for the locally measured voltage as follows ..."
http://www.energy.ca.gov/electricity_an ... ns_v1.docx
