Прошу помощи.
Затрудняюсь с переводом: reduced trim/reduced ball trim
Контекст: спецификация на регулирующий клапан
Конкретнее:
1) The minimum size for control valves shall be 1” as per the pipe specification. If a smaller CV is required, reduced trim shall be used.
2) Ball valves should be considered as throttling valve for hydrocarbon services with cocking tendencies, erosive services, or suspended solids where settlement in globe valve body may occur. The use of reduced ball trim is allowed.
3) If the valve is specified to have reduced trim, the seat ring and plug or cage post area shall be reduced, but the body shall remain as specified. Reduced trim shall be replacable with full sized trim.
Данная спецификация определяет trim как: all those parts of the valve assembly that are in contact with the line medium consisting of, but not limited to, the seat ring, plug, stem, plug guide bushing and cage.
Заранее спасибо!
